97-98 Auto To Manual Swap
Old Jun 24, 2005 | 02:20 PM
grn98lude's Avatar
WHAT DO I NEED PARTS WISE TO DO THE SWAP AND HOW MUCH DOES EVERYTHING RUN. I JUST BOUGTH MY KOUKI BUT I DON'T LIKE THE AUTO MY LAST CAR WAS MANUAL AND I MISS IT ALREADY.PLEASE HELP. OR SHOULD I JUST BEAR WITH IT AND WAIT UNTIL I AHVE ENOUGH TO DO THE SRDET20 SWAP??
INPUT PLEASE, THANKS
Old Jun 24, 2005 | 02:40 PM
2fast4y0u's Avatar
just wait until you do the swap...that way you get a manula trans
parts you will need
clutch pedal set
manual ecu
slave cylinder
clutch master cylinder
all fluid lines required
shift boot and shifter bezel
manual transmission crossmember
manual tranny mount
Old Jun 25, 2005 | 03:48 AM
Levi SPL S14's Avatar
parts you will need
clutch pedal set
manual ecu
slave cylinder
manual tranny mount
You forgot
Brake pedal (they are different)
Oh and DONT POST IN CAPS IT ANNOYING. GO TO YOUR LOCAL MECHANIC TO SEE WHAT THE PRICE WOULD BE.
SEARCH FUNCTION DOES WONDERS.
Old Jun 25, 2005 | 12:45 PM
2fast4y0u's Avatar
Werd /\
Old Jun 27, 2005 | 07:15 AM
SHIFT_Sideways's Avatar
*this should be asked in drivetrain*
Old Jul 3, 2005 | 10:03 PM
bcvjj21's Avatar
dont forget the manual driveshaft
Old Jul 3, 2005 | 10:09 PM
Initial Daniel's Avatar
And don't forget to press "caps lock", and turn it off. Good luck.
Old Jul 4, 2005 | 09:29 AM
2fast4y0u's Avatar
you actually dont need the whole drive shaft. u just need the piece that connects the drive shaft to the trans...thats what is different length. but get the whole thing so there is no problems
spoolin240
Apr 13, 2004 09:46 PM
49240SX
Dec 29, 2003 10:47 AM
BeDrift
Sep 29, 2003 08:12 AM
kidzik007
Apr 20, 2003 12:53 PM
Import Fanatix
Dec 16, 2002 12:01 PM
