car trouble
Old Oct 18, 2005 | 08:11 PM
Sil80 type X's Avatar
Unhappy car trouble
ok so monday morning im driving to work, my gas needle is right on E and im stuck behind a road block (two slow cars barely doing the speed limit) so when the block breaks, i gun it and go, by the time i make it to 3rd gear my car starts to sputter a little bit and then i have no more power and the car is shaking, so i coast into a gas station thinking i ran out of gas and im lucky that i made it to the pump. so i add gas and crank it, and it idles at 5 to 600rpm and is realy jerky and is blowing out black smoke that reeks of raw gas. so i drive it a mile to work and i have no power at any rpm and all i smell is gas. ok now for the tec info. (props to ZYaL8tr for the help over the phone)ok i checked all the fuel injectors to see if any of them where bad and they all ohomed out to 11.6, i swaped the MAfS with my other one i have and still nothing. then i checked the voltage on the O2 sensor and had .02 volts on white to ground. i just replaced the O2 sensor like a month ago, but does anybody know about what the O2 sensor should be reading? i know perfect it should be .45, but i dont know what it should be reading with the engine running rich. also, i have the high pressure fuel pump, could my fuel regulater of gone bad? i just discovered the day before that i have a leak under the throttle body could that of ruined the sensor?
jackibenoist
Mar 25, 2009 06:48 PM
smoken805s14
Mar 12, 2009 07:17 PM
zeroeffect
Jun 12, 2006 08:13 AM
Little_Red_Rock
Jan 11, 2005 03:34 PM
Jonas
Dec 14, 2002 05:43 PM
