cold compression test?
Old Feb 19, 2004 | 08:20 PM
Sil80guy's Avatar
ok,so how is it possible to check compression on a motor that is not in a car?
i was told that one way is to hook up jumper cables pos to starter,and neg to bellhousing bolt,ground?
Old Feb 19, 2004 | 10:15 PM
Put the compression tester on the cylinder you want, and then manually crank.
Old Feb 20, 2004 | 10:18 AM
Sil80guy's Avatar
YOU have actually tried that and it worked???
Old Feb 20, 2004 | 11:52 AM
Yea, worked for me, had 140-150 across the board for me.
epoxy
Feb 23, 2004 09:28 PM
fastback240sx
Oct 4, 2003 08:25 PM
240baja
Feb 16, 2003 01:19 PM
agressiveracing
Northeast
Oct 30, 2002 09:27 AM
