Engine vs Front Clip
its all in the title, what is the advantage of getting a whole (S14 SR20) front clip vs just a the engine? also if you get the front clip are the suspension monts different on the JDM Silvia compared to a usdm 240, also will stock 240 panels fit on a jdm front clip?
Advantage of the front clip is that the engine mostly goes untouched with everything intacked wiring harness, ECU, engine, transmission, intercooling, etc.
When you just get a BOXED engine, transmission, sometimes parts go mysteriously missing.
The only difference you pay for is in the shipping cost. Front clips can run a budget.
Originally posted by keioffice
how so? you dont get body panels. lights or anything like that.
is the stock JDM front (and rear) suspension mounts the same as USDM version 240? meaning will suspension that is for a JDM silvia 14 fit on 95-96 240, or do is the front just different between them and the back the same.
Carparthookup
Nov 19, 2005 07:01 AM
S13freak
May 14, 2004 01:41 PM
craigkiel
May 1, 2004 10:44 PM
