Gonna Start To Remove My Engine
Old Oct 28, 2009 | 12:32 PM
ztkrevolution's Avatar
Question Gonna Start To Remove My Engine
Yep. Dont exactly know what I am doing but i have some help from someone who has swped engines in a mustang. So does anyone have any suggestions
Old Oct 28, 2009 | 02:34 PM
shaban's Avatar
Suggestion: Google and search button.
Been done a million times, and plenty of write ups.
Old Oct 28, 2009 | 08:16 PM
no i just mean like minor thngs like where to start or things to look out for
Old Oct 28, 2009 | 09:03 PM
carps13guy's Avatar
i would start by unclipping the wiring harness and labeling everything as you go. they have these number stickers that i found at a electrical shop that help organize everything & make it way easier when your installing everything. other than that dont b in a rush & start hacking stuff up to remove it & you should b good
Old Oct 28, 2009 | 09:10 PM
or just take the entire harness off and leave everything plugged in. but first you'll need to drain and purge all fuel, oil, and coolant lines and resaviors.
Old Oct 29, 2009 | 04:16 PM
how do i drain the feul?
Old Oct 29, 2009 | 04:48 PM
JapanS15's Avatar
disconnect the lines and let it drain into a bucket that won't disolve from the gas.
Old Oct 31, 2009 | 04:03 PM
positron's Avatar
S13 KA24DE Engine Removal https://www.s-chassis.com/forums/how-tos-installations-48/s13-ka24de-engine-removal-42397/ Take it slow.
Old Nov 1, 2009 | 03:00 PM
JapanS15's Avatar
I would definitely label everything as far as the harness goes. Don't rush...that only leads to mistakes or forgotten connections. Research first, then start the removal.
Old Nov 1, 2009 | 10:50 PM
240smoke's Avatar
dont forget to disconnect power steering lines. I can pull a KA out in an hour because I have done it so many times. its cake.
Old Nov 2, 2009 | 09:34 AM
1SXY240's Avatar
lol ditto ^ I can't do it in an hour, I'm more of the hour and a half to two lol
Old Nov 21, 2009 | 07:30 AM
all right thanks guys sounds good but the engine i have is complete ****. is there still anything i should keep that are needed or can be used on the SR20DET, o and keep in mind the harness is totally F-ed up all the wires are split
Old Dec 2, 2009 | 08:21 AM
Pillion240sx's Avatar
Yea your speed sensor on the trans and the drive shaft dust collar are keepers. Look up positron's KA pull on here the guy did a great write up, I pretty much followed his when i pulled mine.
Tireburn
Jan 26, 2004 02:30 PM
Doba's240
Oct 25, 2003 07:34 PM
TruDirtyPlaya
Jul 24, 2003 07:16 AM
leiferik1
Feb 9, 2003 09:52 PM
hurleyboi514
Mar 11, 2002 11:07 AM
