-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   Gonna Start To Remove My Engine (https://www.s-chassis.com/forums/engine-swaps-13/gonna-start-remove-my-engine-46475/)
ztkrevolution Oct 28, 2009 12:32 PM
Yep. Dont exactly know what I am doing but i have some help from someone who has swped engines in a mustang. So does anyone have any suggestions
shaban Oct 28, 2009 02:34 PM
Suggestion: Google and search button.
Been done a million times, and plenty of write ups.
ztkrevolution Oct 28, 2009 08:16 PM
no i just mean like minor thngs like where to start or things to look out for
carps13guy Oct 28, 2009 09:03 PM
i would start by unclipping the wiring harness and labeling everything as you go. they have these number stickers that i found at a electrical shop that help organize everything & make it way easier when your installing everything. other than that dont b in a rush & start hacking stuff up to remove it & you should b good
jramosthe1st! Oct 28, 2009 09:10 PM
or just take the entire harness off and leave everything plugged in. but first you'll need to drain and purge all fuel, oil, and coolant lines and resaviors.
ztkrevolution Oct 29, 2009 04:16 PM
how do i drain the feul?
JapanS15 Oct 29, 2009 04:48 PM
disconnect the lines and let it drain into a bucket that won't disolve from the gas.
positron Oct 31, 2009 04:03 PM
S13 KA24DE Engine Removal https://www.s-chassis.com/forums/how-tos-installations-48/s13-ka24de-engine-removal-42397/ Take it slow.
JapanS15 Nov 1, 2009 03:00 PM
I would definitely label everything as far as the harness goes. Don't rush...that only leads to mistakes or forgotten connections. Research first, then start the removal.
240smoke Nov 1, 2009 10:50 PM
dont forget to disconnect power steering lines. I can pull a KA out in an hour because I have done it so many times. its cake.
1SXY240 Nov 2, 2009 09:34 AM
lol ditto ^ I can't do it in an hour, I'm more of the hour and a half to two lol
ztkrevolution Nov 21, 2009 07:30 AM
all right thanks guys sounds good but the engine i have is complete ****. is there still anything i should keep that are needed or can be used on the SR20DET, o and keep in mind the harness is totally F-ed up all the wires are split
Pillion240sx Dec 2, 2009 08:21 AM
Yea your speed sensor on the trans and the drive shaft dust collar are keepers. Look up positron's KA pull on here the guy did a great write up, I pretty much followed his when i pulled mine.
