Is this a good set up?
ok. i am almost down for buying the sr20det silvia front clip.
but have extra cash to throw in for performance. with the sr20 in the garage, i want to buy and install: - Garret T3 turbo (found one for $350) - sr20 topmount for T3 exhaust monifold (polished and chromed out) ($250) - Electrnic Boost controller ($150) - Greddy front mount intercooler ($200) - JWT S3 cams ($300) - Unorthodox Racing underdrive crank pulley ($100) - Greddy S13 Pulleys ($200) - 555cc/hr injectors - Sequential BOV - S13 255 high pressure Walbro Fuel Pump ($100) - 3" Catback with high flow catalyc converter thats pretty much want i want in my SR20. is it a good setup? please tell me now, because i dont want to regret after buying it. appreciated. |
Moved to engine swap section
3" downpipe and exhaust system in there somewhere? |
i didnt really think about the downpipe but i think i am gonna have to get a custom one since my turbo is gonna be mounted on top.
so its gonna be Turbo > 3" Custom Downpipe > High Flow Cat. > 3" Catback with the muffler. |
Those injectors are gonna require some kind of management I think-probably a AFC at least.
didnt think about that. ok. dont the AFCs run for like $300 ?
To modify the timing, remove boost cut, remove rev limiter, you're gonna need an ecu upgrade (JWT $600) and not just an AFC (which you should get to fine tune). The intercooler is going to need pipes to connect it ($600) How did you find a Greddy intercooler for only $200??? Also make sure that t3 is in good condition. What are the specs on the turbo?
intercooler. its used. my friend had a talon. and he sold it, but kept the expensive parts. so he will sell the frontmount for about $200.
HKS Garrett T3 specs: .36" INLET DIAMETER 2" OUTLET WET FLOATING BEARINGS 1/8 NPT OIL INLET T3 / T4 FOOTPRINT OK FITS T3 AND T3/T4 MANIFOLDS . 42 A/R COMPRESSOR .48 A/R TURBINE |
