Help!!
:help: i have an sr, and i bought it from a guy that crashed into a tree....it looks like instead of taking off the head to remove the cracked front oil pump cover, it looks like he just got a screwdriver to pry it off....there are chips all around the blocks surface, and seriously ive never been through a problem like this before.....i dont kno what to do???...its either resurface the block or put sealent around....i want to be safe!!!...any suggestions??..:dunno:
damn brother..first that was a bad purchase... i would resurface it.. many sealants break down over time for various reasons ( heat) i would have it resurfaced. you can even do it yourself with an sander and high grit paper.
JB Weld, then sand smooth?
Its just chips? Not a crack? If so yeah sand it down and polish it off. If this guy did stuff like that, your gonna wanna go over that engine with a microscope.
Originally Posted by OutToWinPAHC
(Post 320137)
Originally Posted by ryguy
(Post 320113)
(Post 320086)
well i think most who have owned a 240 have made one bad purchace atleast. just learn to look more closely at what you buy next time. 3rd owner eh? for some reason that makes me nervous. i have a feeling that engine might have some more surprises waiting for you. done a compression check yet?
Originally Posted by cracka Matt
(Post 320153)
(Post 320153)
The JB Weld won't melt. You can use it on cracks on engine blocks. And Wes_R20 stop double posting. Put everything you have to say in one post or use the edit button.
