i cant put more than 25% throttle with out it bogging
Old Oct 11, 2005 | 12:47 PM
colombia's Avatar
i have fanally finished my swap but i cant rip it, i baby the throttle and it will drive smooth but a s soon a s i push on the gas it pop sputters and sounds like its fluding. i have heard about rubber intercooler pipes colapsing on themselves and since i have the stock intercooler system i was wondering if anybody else hads heard of this problem. i was also wondering if anybody has ever heard of a field boxer racing chip with an on off button thanx\\
Old Oct 11, 2005 | 12:54 PM
naptime's Avatar
Have you checked for vacuum leak? Have you checked the plugs? wires? MAFS?
Old Oct 11, 2005 | 02:34 PM
2fast4y0u's Avatar
go with what naptime said.... check all that out. also, make sure your fuel delivery is ok. you might have a clogged fuel line
Old Oct 11, 2005 | 03:08 PM
nsn240's Avatar
check the vaccum lines and fuel delivery... make sure it isnt running too lean or to rich
Old Oct 13, 2005 | 03:49 AM
jonpowell's Avatar
Tune up, spark plugs, etc...
Timing needs adjustment.
Old Oct 17, 2005 | 04:04 PM
bennieb's Avatar
make sure no holes in intercooling pipes
Old Oct 17, 2005 | 05:02 PM
Initial Daniel's Avatar
It's a good idea to check everything...not just the things listed. What kind of swap is it, btw?
Old Oct 17, 2005 | 06:45 PM
Garik's Avatar
Sounds like intercooler piping came loose somewhere. I had exactly same symptoms when my ic pipe came loose.
shaban
Dec 6, 2012 09:05 AM
Carparthookup
Oct 11, 2005 10:08 PM
240ZeN
Aug 22, 2004 01:54 PM
Strizzy
Aug 26, 2003 01:15 PM
MotoMatrix.com
Jul 1, 2003 12:31 AM
