ka-t vs. rb25det
see man when you say something like that it makes me even want the rb more. my ka right now skids out alot so i can imagine the rb. another question i have you since you have the rb is 1-whats the most boost you can boost on a daily driver? 2- i know alot of people say the rb can handle 25+ psi but how much can the valvetrain handle? 3- did you rebuild it when you put it in and whats parts did you rebuild? i know you need the fuel pump radiator fans intercooler mount/driveshaft belts clutch, but what else do you need is the water pump really necessary or can i put all those things in and drive it like it was a stock ka and not worry bout a thing?
13.5PSI
Valve train usually have problems with high RPM...I have NEVER heard anyone say the RB25 can handle 25+psi stock.
I ONLY changed head gasket, water pump, thermostat, timing belt & spark plugs.
The water pump is NOT necessary if you like driving around holding a hand grenade with the pin pulled.
DO NOT BE A CHEAP *** AFTER SPENDING $3500+ ON THE MOTOR
Its the STUPIDEST thing I see all the time...spens a ****load on a new motor then cheap out when installing it. The motor is a daily driven motor in Japan....it is the same here.
