Mufflers No back pressure!!
Old Jul 9, 2004 | 07:34 PM
240sxs042's Avatar
I heard that if you have and engine within a 100-500hp range then you could have a to big of a muffler because it will let out to much backpressure? Is that correct if so how do you know if it is to big? Can you test or diagnose how much your losing?
thanks
Old Jul 9, 2004 | 08:23 PM
xjon's Avatar
Check with dyno, butt dyno, g-tech .....
Turbo cars don't need back pressure. Do a search on what is appropriate size of piping for your engine. Should have been discussed or argued about.
Old Jul 10, 2004 | 08:10 PM
hitokiri_808's Avatar
back pressure is what you want to get rid of. scavanging is what you want.
Old Jul 11, 2004 | 06:19 PM
BoogiepopJDM's Avatar
3" piping with an apexi N1 style muffler seem to be ran by most ppl with a turbo application, and yes you do need some kind back pressure of some sort if you dont youll loose almost everything at the low end.
Old Jul 12, 2004 | 05:57 AM
PROJECTRB240SX's Avatar
SOME BACK PRESSURE IS GOOD ON NA CARS..... ON TURBO CARS BACK PRESSURE NEED NOT APPLY.
Old Jul 12, 2004 | 12:42 PM
xjon's Avatar
I ran my KA with the 3" N1. I thought it ran good. I figured the cat was restrictive enough.
Old Jul 12, 2004 | 12:57 PM
THE DOWN SIDE TO BACK PRESSURE IS LOWER TOP-END BETTER LOW END POWER.... WITH LITTLE TO NO BACK PRESSURE YOU'LL GET A BETTER TOPEND.
D Grade
Nov 29, 2005 10:00 AM
dacheat
Feb 24, 2005 08:50 AM
bztech
May 19, 2004 06:38 PM
ahnyoungboi
May 18, 2004 02:27 AM
bztech
Apr 12, 2004 06:29 PM
