View Poll Results: Is the large presision front mount inter-cooler worth $500
yes
60.00%
no
40.00%
Voters: 5. You may not vote on this poll
my sr20 sit uneven, why???
Old Apr 17, 2005 | 02:41 PM
advanced240's Avatar
ive got the motor in and the mounts back on and i cant seem to get it to level out. the left side of the motor is lower that the right have any of you ever encountered this problem??? is their a spacer that i could use to level it....
Old Apr 22, 2005 | 06:07 AM
TWAN's Avatar
Double check your motor mounts. They can only go on one way. Also make sure you removed the AIV from the down pipe from the turbo. If you didnt more than likely it is sitting on your steering assembly. If either of these arent the case you might have the wrong mount on one side or a busted mount. Hope this helps.
Old Apr 22, 2005 | 12:43 PM
whats your poll have to do with this question...
Old Apr 23, 2005 | 01:44 PM
98cwitr's Avatar
^he might be killing two birds with one stone, hehe
Old Apr 23, 2005 | 07:08 PM
rkcarguy's Avatar
The motors sit uneven like this from the factory. I have 3 SR clips in the shop right now they all sit uneven, lower on the turbo side of the engine.
Old Apr 24, 2005 | 10:11 AM
Slidin240's Avatar
Ive noticed that too with the SR/RB motors. Everytime i see one its on a slant (on the turbo side)
Old Apr 25, 2005 | 08:20 PM
thanks a bunch, now i have a new problem "too long of a drive shaft non-abs". thanks a bunch guys...
lifted&lowered
Mar 17, 2010 09:52 PM
jpos985
Jun 24, 2005 09:47 AM
battery1882
May 26, 2005 03:34 PM
CowboyTurbo
Mar 23, 2005 02:01 PM
gtivr4
Jan 27, 2004 10:51 AM
