Preparing for the VG
Old Jul 24, 2005 | 10:16 PM
Fast1One's Avatar
Some of you may know that my KA finally blew up. That thing lasted a while lol... Well, Im doing lots of research preparing for the VG30DE swap I am considering. I found a place that might get me what I need here.
My car is currently an auto therefore I will do a five speed swap at the same time. I did a quick search and found a sticky with this list...
5 speed ecu S14's(optional on S13's)
5 speed trans
5 speed trans crossmember
5 speed driveshaft
manual flywheel with bolts
manual engine backing plate
manual trans to engine bolts
clutch with clutch bolts
(including pilot bushing ,driven disc and pressure plate)
clutch pedal
brake pedal(optional)
clutch line upper
clutch line lower
clutch dampner(optional)
cluth master
clutch slave
lower shift boot with plate(mounts on your tunnel)
upper shift boot (recommend purchase new )
The ones in bold I will recieve with the engine or will be custom. Where can I get this without getting a headache? Im trying to avoid junkyard hunting
The engine mounts will be z31 or custom made by me...Ill probably get a new radiotor and fan. The driveshaft will be custom. And thats what I got so far...Wheewww sorry for the long post. Ok, SO can anyone think of anything else I need????? This is going to be FUN!
Old Jul 24, 2005 | 11:40 PM
rb20drfter's Avatar
hey dude..a buddy of mine did the vg swap..if you want i can give you his aim address and if you have any questions about it he'll answer them...its all stock except for a single t61 turbo...runs 11's...amazing..but yea..just pm me or just reply on here for his aim or email address
Old Jul 25, 2005 | 12:24 PM
Fast1One's Avatar
Well, im just considering it im not sure, ill definately get back to you though. I just found a TT for sale so I might get that lol...
Old Jul 25, 2005 | 09:15 PM
rb20drfter's Avatar
well...its a beast of an engine lol...but yeah..my aim address is turbob18c5hb so if you need any more info or whatever on it just im me
Old Jul 25, 2005 | 10:43 PM
Fast1One's Avatar
Thank you...Anyone wlse want to put in their 2 cents?
Old Jul 26, 2005 | 09:09 AM
BigVinnie's Avatar
Re: Preparing for the VG
5 speed trans
5 speed driveshaft
clutch pedal
clutch line upper
clutch line lower
cluth master
clutch slave
Like Chris Farley, Holy Snikies,
That list already looks like a headache, it's giving me one just looking at it. What does it mean by s14 stick shift ecu? Don't you mean z32 ECU?
Technically you will need the z31 mount's, z31 cross members, z31 drive shaft, z32 engine and transmission.
You can use your existing clutch and brake cylinders.
You will want to talk with Steven Pepka, he is the swapper of the VG30dett into the datsun 510, his work is some of the best, and he will tell you the minor modifications that will need to be done to the mounts and brackets.
http://www.datsuns.com/red/Redpage2.htm
Old Jul 26, 2005 | 11:15 AM
Fast1One's Avatar
Thats why I put those in bold BigV lol...I wont need those. Thats just the list for a five speed swap in our cars...Mines an auto remember??? Ok...where can I locate the z31 parts I need?
Edt: Besides the junkyard.
Old Jul 26, 2005 | 11:55 AM
Justin.b's Avatar
The junkyard.... You're talking about a car that's been out of production since 1989 (Z31). I'd be surprised if you could locate these parts new.
For the clutch master and slave, just get them from your local parts store. You may be able to buy these through a dealer's parts department, but be prepared to pay more than double what you would for a rebuilt piece. The clutch hard lines are going to be easy enough to bend yourself. You may have to go to a foreign autopart store to get the lines with the proper flare fittings on the ends, since the major chains seem to onle carry them in threads used by domestics.
For the 240sx pedal assemblies, try www.car-part.com . It's still junk yard, but at least you don't have to find time to do the parts pulling yourself during business hours.
How is the fit of the DE in a 240SX?
The S13 / S14 have significantly larger strut towers than the 510 / S12 / Z31. The S13 uses a spring of a much larger diameter than those cars, and the strut rod is not centered in the spring mount, so it needs extra room to spin on that axis.
I'm not saying its not possible... I'm just curious. I've never seen a VG/VQ DOHC swap into an S13 or S14.
-Justin
Old Jul 26, 2005 | 12:38 PM
Fast1One's Avatar
Youve never seen this swap Justin.b? Or how about this?
Old Jul 26, 2005 | 12:48 PM
Justin.b's Avatar
Nope. I hadn't seen those, but I have now!
Good luck with the project. Looks like there's more room than I thought between those towers.
-Justin
Old Jul 26, 2005 | 05:01 PM
rb20drfter's Avatar
yeah thats the buddy of mine i was talking about..that car is so sick
Old Jul 26, 2005 | 06:13 PM
BigVinnie's Avatar
Your buddy seems to be a good engineer too, he happen to run both exhaust manis to a single FAT *** turbo, the spool time and QMT must be wicked as shiat. Is that a T82? It's a pretty phat turbo.
If he used the 2 stock turbos and mani he wouldn't of had to relocate the clutch, and brake lines.....
But Oh well, it still a MOBSTER in my opinion.
Old Jul 26, 2005 | 06:54 PM
Levi SPL S14's Avatar
that s13 with the VG is sick my god he is a genius.
Old Jul 26, 2005 | 06:56 PM
rb20drfter's Avatar
yeah...its built for drag...he has a locker rear end so when her turns the tires skip...its badass...he ran a 11.44@126 and 11.30@129 both at 22psi on c14 race gas...the only thing done to it is the t61 single turbo...o and all on street tires
Old Jul 26, 2005 | 08:55 PM
Fast1One's Avatar
Wow...I wish. So awesome....
