problem, any ideas
Old Mar 17, 2006 | 06:26 PM
godfather2112's Avatar
problem, any ideas
While i was stoped at a light today my car suddenly died. We tried to jump, charge the battery and nothing. I do not get a click when i turn the ignition. any ideas
Old Mar 17, 2006 | 11:16 PM
ConceptS14's Avatar
were you able to get the car started when you jumped it?
if it did start and then died when you disconnected the jumper cables, then your alternater is probably dead.
Old Mar 18, 2006 | 12:16 AM
no the car did not even have a click nothing, the only power i get is to the headlights. i cleaned the terminals made sure they were tight and everything. im guessing either the starter or aleternator
Old Mar 18, 2006 | 12:44 PM
ConceptS14's Avatar
take something solid and smack the starter a few times and see if you can start it afterwards.
Old Mar 18, 2006 | 11:20 PM
CowboyTurbo's Avatar
use a non-metal object, I made that mistake once...
Old Mar 20, 2006 | 07:24 PM
where is the ecu located, gonna see if the wiring is melted or the ecu
Tanshin
Oct 31, 2005 03:44 PM
aemneuspeed
Oct 25, 2005 06:34 AM
240sxFreak
Nov 14, 2004 04:55 PM
sr20det power
Jan 7, 2004 07:55 PM
Dorifto180
Dec 22, 2003 07:34 PM
