Problems Need Help Asap
Ok this is the deal. Maybe a month ago I was driving my car and my trans was always messed up so I went from 3 to 4th but instead it went into 2nd gear. I hit rev limiter and the car was all messed up. I opened it up and realized it was a broken rocker arm on the exhaust side. I replaced it, and then put some RAS on. At the same time I had the trans out I swapped the trans and replaced the clutch and resurfaced the flywheel.
PROBLEM #1 I just tried starting the car and its still misfiring like before when the rocker arm was broken. When I checked the compression before when the rocker was broken it was 0 now it reads much higher. However, when I pulled the #4 plug out it was covered with gas. What could this be?? Bent Valve? Needs adjustment??
PROBLEM #2 When I did start the car it made this horrible squeak and when I pushed the clutch down it didnt seem as if it was dissengaging. I tried putting it into gear when the car was started and it wouldnt go in and made this really really bad squeak. I tried adjusting the clutch but still the same thing. Could this be a bad slave cylinder?? Maybe its not pushing the plate all the way or something??
GUYS IM LOST AND NEED HELP PLEASE NO FLAMING AND JUST HELP!!!!!!!!!!!
THANKS,
MARK
THANKS,
MARK
ok i heard it could be the lifters are full with are and thus not not getting compression.
i pulled the valve cover off and i was able to push the lifter down with my finger???
is that right?? should it not be hard and full with oil??
PLEASE SOME INPUT WOULD HELP
skillzilla
Feb 8, 2004 09:08 PM
