Ran my sr20 at the strip
Well I finally got a time I'm decently happy with at the strip. I've only gotten to run my car minimal times since I have not had it long, but anyways here is what my time slip said and my mods.
My mods are as follows:
SR20DET BT, HKS Intake, Blitz 3'' DP, 3'' test pipe, 3'' SS Catback, HKS FMIC, Greddy hot pipe, Greddy oil pan, Walbro 255lph Fuel pump, and an HKS turbo that came over with the motor that I lucked out and got to keep. Not sure which HKS turbo it is, but I was only running 9lbs with it, and I was on Yokohoma AVS ES100's.
R/T: .720
60': 2.037
330: 5.845
1/8: 8.948
MPH: 80.98
1000: 11.629
1/4: 13.886
MPH: 97.69
I'd say I did pretty good, I would really like to see if I could pull of a 1.9 60' on street tires, but not sure if its possible. What does anyone think? I'm sure I could get a 13.7 with a 1.9 60' but who knows. I am getting my boost controller installed this upcoming week, and plan on going back and running 13lbs hoping to see low mid 13's, but who knows??? I will be getting some 550 injectors soon enough and something to tune the car with, and going to try 20lbs on the turbo and see if she takes it, hoping to see 12's with that setup and some slicks.
Oh well just wanting to know what people think about all this? Comments, suggestions, all are welcome. Thanks.
R/T: .720
60': 2.037
330: 5.845
1/8: 8.948
MPH: 80.98
1000: 11.629
1/4: 13.886
MPH: 97.69
Whoops, haha forgot about that little info.
I have an ACT XTSS clutch and a Silvia stock LSD
I also lowered my tire pressure down to 20psi and I was practicing launching between 4k-5k and found the best area was right about 4300 RPM's slipping the clutch. I figured since I'm so close to that 1.9 mark that it can be done with more practice, putting me into the 13.7's. However the next time I run it will be with 13lbs of boost instead of only 9lbs so the times should be lower then 13.7's if I can get traction. Untill then please keep the comments, suggestions coming. Thanks.
