reverse light problems
Old Aug 27, 2005 | 03:20 PM
apxlink's Avatar
i juss swapped my car from an auto to manual ... 1 problem is that i dont kno where to wire up the reverse lights near the shifter, any help would be great. thanks!
Old Aug 27, 2005 | 04:08 PM
Fast1One's Avatar
Im not knowledgable in the five speed swap but...
now the easiest thing to do wiring is wire up your back up lights by looking at a FSM or haynes manual and tracing the back up light wires on your auto trans and cutting that wire out of your auto trans harness which you have already removed from your engine compartment. You will also take the plug from it as you will need it to hook it into the wiring on the car.
I got that from the "5 Speed swap" sticky in the FAQ section...Try getting an FSM...search the forums I think there is a link where you can download one...
Old Aug 28, 2005 | 02:33 AM
apxlink's Avatar
alright thanks a lot. i will take a look tomorrow and try to find the wire. =D
akaihachi
Jan 10, 2005 03:04 AM
Ilsccjokr
Nov 12, 2004 06:53 PM
dori2 s13coupe
Mar 12, 2004 10:27 PM
dori2 s13coupe
Nov 12, 2003 04:32 PM
altima/240sx
Nov 14, 2002 05:08 AM
