s13 sr20det idle problem..please please help me =(
Old Apr 4, 2004 | 05:36 PM
japporeyser's Avatar
just finished the sr swap and the car does start and idles..but the rpms are jumpy b/w 800-1700 rpms and when the gas is revved at around 2000 rpms..the car cuts off...just wondering what is causing this and how to fix these..its been way too long and i need and want to drive the car...please please help me and thanks for your help in advance...
Old Apr 5, 2004 | 11:52 AM
89s13drifter's Avatar
Sounds like a problem with the maf or cas.
Old Apr 5, 2004 | 02:47 PM
tegg_gsr's Avatar
wiring maybe?
Old Apr 7, 2004 | 08:03 PM
s240r's Avatar
02 sensor is my guess
Old Apr 7, 2004 | 08:15 PM
Driftmonster's Avatar
Check and change your sensors, I had some MAFS probs with my car. Reset your ECU also after you change any of the sensors, by simply unhooking the neg on the battery.
Also unhook your MAFS and your battery, then hook the battery back up and start the car (without hooking up the MAFS). let it run for a few minutes (will run like ****), then shut it off and hook up the MAFS, and start again.
This sounds really weird, but I swear it worked for me.
bs280
Sep 19, 2006 12:03 AM
uvamosk
Aug 12, 2005 07:31 PM
89s13drifter
Apr 7, 2004 06:34 AM
chainz
Apr 13, 2003 03:12 PM
