s13 sr20det to s13 240 wiring diagram
Old Apr 16, 2006 | 03:30 AM
RB26DETT_240sx's Avatar
I got bored at 5:10am for looking for a sr motor, so I went to srswap.com and copied the wiring diagram, for the lazy bastards, to show how to do it yourself, and save a few hundred dollars!!!
There are 2 plugs on the end of the KA harness and 3 plugs on the SR harness that run up behind the stock battery location. Although the plugs do initially snap together, the wires do not line up and you have to cut the plugs off and connect the wires using the table below. Cut the 2 main KA plugs off the KA harness and splice them onto the SR harness.
red lines are SR Harness
blue lines are KA Harness
SR Harness Wire Color
Used For
KA Harness Wire Color
Black / Pink stripe
Fuel Pump Relay
Black / Pink stripe
Green / Orange stripe
Transmission Neutral Sensor
Red / Black stripe
ECU Relay
Red / Black stripe
Green / Yellow stripe
AC Relay
Red
ECU Backup Power
Red
Black / Red & Blue / Red (Note: connect 2 wires to 1)
Main Ignition Power
Black / Red stripe
Black / White stripe
ECU Power
Blue / Green stripe
AC Relay
Blue / Green stripe
Black / Yellow stripe
Idle Air Control Valve Power
Brown (to O2 sensor)
O2 Sensor Power
Any 12v switched source
my source
like I said I got really bored in the early morning of easter, so all you freeloaders here you go, please quit asking for the wiring diagram.
sorry if this has been posted before, I searched but didn't see it, so here you go!
Old Apr 17, 2006 | 03:32 AM
jonpowell's Avatar
Are you going to type up the rest of it? There is another plug you gotta do work to.
Start signal
Tach signal
Speed signal
CTS signal to gauge
MIL signal
Your "Guide" wont even start it easily. Anyone who uses it will need to blip the throttle for the motor to even fire.
It is pretty irresponsible to post half the info & call it a diagram...
Everything you have is correct, you just dont have it all
Old Apr 17, 2006 | 10:27 PM
Start signal
Tach signal
Speed signal
CTS signal to gauge
MIL signal
YO, I didn't say it was my guide, I got the info above from Heavy Throttle, and COPIED it to here!
ECU & Dash wiring
The colors on the wires that run from the ECU up into the dash matched up perfectly on both the SR ECU harness and the KA dash harness:
Wire Color
Used For
Yellow / Red stripe
Tachometer signal
Yellow / Green stripe
Speedometer signal
Orange
Ignition start
Black (may be more than one ground)
Ground
Blue / Green stripe
AC signal
Blue / Black stripe
Water temp signal
The rest of the wires are for the CONSULT diagnostic device. It is not necessary to connect any other wires than those listed above to get the SR to run properly.
Connect the remaining wires if you plan to use the onboard diagnostic CONSULT connector.
The Apexi turbo timer is connected to the O2 sensor wire at the ECU to provide auto countdown functions. The Apexi AVC-R is also attached to the ECU harness for tachometer signal, speed signal, and throttle position. Apexi products come with a very good ECU pinout diagram that is extremely useful.
Remove the brackets from the SR ECU to make it easier to mount.
There you go the rest of what Heavy Throttle has on the wiring!!!
Old Apr 18, 2006 | 03:31 AM
jonpowell's Avatar
Yellow / Red stripe
Tachometer signal
Speedometer signal
Orange
Ignition start
Ground
Blue / Black stripe
Water temp signal
All of this was omitted in your origional "guide" I think if you are gonna do it, do it.
It's nice that you did it, dont get me wrong...Being in the wiring business, I know how lazy and stupid alot of people are and by you posting up HALF the info, some would think its actually ALL of the info. What you did was great in theory, however by halfway doing it you actually did alot of people a greater diservice that not doing it at all because they would do everything you said & think its all done.....believe me.....I have heard EVERYTHING.
Old Apr 19, 2006 | 03:27 AM
well i wasn't done with the post yet, I forgot to put that in there, but either way its complete now!
its finished!
Old Apr 27, 2006 | 04:47 PM
airlu's Avatar
Just the other day, I can not start my 240sx w/ SR20DET swap, but, I couldn't tell why. I looked in my engine bay, by the starter wires and pass. side engine mount, and realize two wires are disconnected (a brown wire and a black wire), but, I am not sure from where. Hoping someone can tell me where they are suppose to be and where they are connect to or not connect to anything at all. Now my car doesn't even turn over or click, but, it has power. Please help. Thanks in advance.
davvvid
Sep 27, 2006 09:58 AM
chuckie500
Sep 12, 2004 04:40 PM
sr20-s15foo
Nov 21, 2002 12:26 PM
DiZZy
Nov 10, 2002 02:21 PM
SX_Drifter
Oct 11, 2002 10:10 PM
