S14 S13 Difference?
Old Mar 16, 2005 | 07:42 AM
DirtyRotn240's Avatar
S14 S13 Difference?
Doing a little research between the differences between the S13 SR20DET and the S14 SR20DET. Currently looking for an engine for a '97 240SX LE
S14 SR20DET's use a different ECU and harness, these are extremely expensive and hard to find. Easy enough...now what about other stuff
I think this is info from a S14 T28 VTC?? Is there a difference from a S14 BT?
Horsepower: 220hp at 6000rpm Torque: 203 ft/lbs at 4800rpm
Variable valve timing system and a different turbo are the significant changes from the S13 SR20DET engines. S14 uses 'low port' intake design vs. S13 'high port' design.
Now are performance parts and accessories harder to find aor more expensive then the S13? Anyone else got more info on the S14 vs S13 engines?
Anyone got good info on the differences? I will dp more browsing but if anyone has experience with the S14 I would appreciate it.
Old Mar 16, 2005 | 09:15 PM
rkcarguy's Avatar
After scratching my head, I have to say......SEARCH!
soul strong
Apr 3, 2008 12:41 PM
TOMMY94GT
Jan 18, 2006 12:32 AM
l3ooherS14
Jul 21, 2004 04:36 PM
49240SX
Nov 18, 2003 04:57 AM
StanBo
Jul 27, 2003 05:19 AM
