S14 SR20 into a S13
Old Dec 13, 2006 | 11:27 PM
AZdrifterS13's Avatar
S14 SR20 into a S13
So my question is it worth the extra couple hundred dollars to buy the S14 SR instead of the S13? The S14 is rated at 220 hp, and the S13 is 205 or something. I'm planning on upgrading pretty much everything, including the turbo, IC, fuel system, everything. So is it worth it, is there anything thing that make it harder to put the engine in the S13 or is it basically the same thing?
Old Dec 15, 2006 | 08:24 AM
JamesS's Avatar
If you are going to go replacing everything , then no not really going to be worth it. S14 has variable valve timing and differences in the head that CAN limit you to what cams you will use. S13 can be cheaper but they are older.
Short answer is, go with a S13 if you are going to be replacing everything anyways.
Old Dec 15, 2006 | 02:28 PM
2plus4plus0EQ6's Avatar
i went with the s14 into my s13 because I read somewhere that the s15 6speed tranny will fit onto my s14 engine (i think i will need the s15 rear end aswell). eventually i'll probably do this.
plus the engine is newer which is nice and looks better in my opinon. don't be cheap just get the s14
Old Dec 15, 2006 | 05:57 PM
s15 tranny sucks anyways
Old Dec 15, 2006 | 06:18 PM
hell yeah I heard it blows. makes alot of noise and can't handle horsies. It sure would be nice to have a 6-speed though. I'll just get a holinger sequential. haha.
nissan SR20
Aug 12, 2006 01:07 PM
hamburgler
Apr 14, 2006 01:22 AM
drftordie
Jan 23, 2004 11:02 AM
j-z
Nov 16, 2003 03:54 PM
TruDirtyPlaya
Jul 8, 2003 08:46 PM
