sr20 help
Old Mar 12, 2004 | 10:13 PM
doua's Avatar
sr20 help
I know that this question been ask befor and my time with out a good answer from any one. How do you hook up you RPM gauge. This RMP gauge is from auto meter. what other wire can you hook it up to. I try the ECU wire but it won't work. From my old KA motor I hook to to the coil. But Where can I hook it up to for the SR............ Please help.
Old Mar 14, 2004 | 01:52 PM
s240r's Avatar
i just hooked up my tach, run it to the cam anlge sensor. It is the round harness on the right front of your valve cover. There should be 4 horizontal wires coming out of it. The one that is all white is the wire you should run you signal wire to. let me know how it turns out.
Old Mar 15, 2004 | 03:39 PM
doua's Avatar
thank man! I will try and see what happen.
eDmsIl80
Aug 10, 2011 06:18 PM
war
May 30, 2004 04:33 PM
gtivr4
Jan 27, 2004 10:51 AM
s15con240
Apr 15, 2003 05:49 PM
leiferik1
Oct 13, 2002 08:45 PM
