sr20 problem please help!
Old Nov 21, 2004 | 10:46 PM
james_s14's Avatar
my car has been running fine, but tonite when i was driving, i felt hesitation in 2nd and 3rd gear..basically, when i start to push down on the throttle at 2nd and 3rd gear the engine starts to feel like its bogging...like hesitating, then then i push more on the throttle and its ok..when im in 3rd im at about 2000 rpm..any suggestions? thanks guys. oh yeah, i was running bout 94 octane..
Old Nov 22, 2004 | 06:21 AM
srslider's Avatar
have you checked your fuel pressure, How much boost are you running. You might want to change the fuel filter, would be a good step in the right direction, maybe.
Old Nov 22, 2004 | 10:14 AM
james_s14's Avatar
i put a 300zx fuel filter in not too long ago, i just changed oil too, i havent checked fuel pressure...dont know how...but i did get a walbro fuel pump today...im running about 10 psi boost.
Old Nov 22, 2004 | 10:15 AM
james_s14's Avatar
i put a 300zx fuel filter in not too long ago, i just changed oil too, i havent checked fuel pressure...dont know how...but i did get a walbro fuel pump today...im running about 10 psi boost. i havent installed the fuel pump yet though...i also bought an apexi safc2 that i havent installed yet.
Old Nov 23, 2004 | 01:35 AM
james_s14's Avatar
problem update: it hesitates in all gears now..if i push down on the gas, it feels like its hesitating alot...my friend said my fuel pump might be going out..or maybe my air flow sensor??? please guys, any suggestions?
Old Nov 24, 2004 | 07:22 PM
james_s14's Avatar
update: replaced fuel pump with the walbro....fixed everything, period. now its time for dyno tune with the s afc.
Old Nov 26, 2004 | 02:15 PM
srslider's Avatar
good, glad it worked out for you. Let me know what you numbers are on the dyno. Sorry it took so long to write back but I've been out of work.
trickd240
Jul 19, 2006 05:52 PM
uvamosk
Aug 12, 2005 07:31 PM
japporeyser
Apr 7, 2004 08:15 PM
chainz
Apr 13, 2003 03:12 PM
chainz
Mar 9, 2003 04:05 PM
