SR20DET alternator swap
Old May 13, 2006 | 05:57 PM
robalicious96's Avatar
I need to swap out my alternator on my S13 engine. i kinda got the basic idea on how to do it but i was wondering if anyone knew where a write up on one was... or has done it themselves.
Old May 13, 2006 | 09:03 PM
Levi SPL S14's Avatar
umm its like 3 bolts and a belt.
Old May 14, 2006 | 04:26 PM
umm.... ok.... is that really it. what about the tensioner.... and where exactly are the 3 bolts located at because i see more than 3 on there
Old Jun 5, 2006 | 11:10 AM
carkid0007's Avatar
The bottome bolt that has a 14mm nut on the end where the alternator can pivot. Then the one at the top that I believe is a 12mm, then take the wires off the back one is a 8mm, and the other is a 10mm, and one connector, should come right out
carkid0007's Avatar
The bottom bolt that has a 14mm nut on the end where the alternator can pivot. Then the one at the top that I believe is a 12mm, then take the wires off the back one is a 8mm, and the other is a 10mm, and one connector, should come right out
got_psi?
Jun 27, 2010 01:27 PM
flipboi96zx
Sep 13, 2009 09:09 AM
RB26DETT_240sx
Sep 7, 2006 02:26 AM
DevilsSi1481
Mar 29, 2006 11:26 PM
Skiboard06
Jun 19, 2005 11:19 PM
