Sr20det BOOST
which one? redtop black usually 13-15psi for safe.. it comes with 7psi stock. go here *****! http://srswap.com/ and go to motor faqs!
no...he's saying up to 10 psi is safe w/ stock SMIC and a upgraded fuel pump...want to go higher...get a better intercooler...then you can go ~14 psi.....after that you're beyond the efficiency of the turbo...if you want to go higher than that get a better turbo and upgrade your injectors...wouldn't hurt to upgrade injectors...then you need to get an SAFC to control
drf3rsmok3on3
Jul 31, 2005 03:24 PM
sil_8dee
Aug 24, 2004 05:01 PM
