sr20det + dofferential
i recently bought a tomei 2way lsd for my open differential pumpkin. With that said, if i want to swap in a sr20det with the tranny in the future, will i be able to use the stock ka24e differential?
If not, is there something i could do....like buy a new driveshaft or something?...cause i want to keep the 2 way differential.
Originally posted by s13 240
The rear differential has nothing to do with the engine that is in the car. Everything will still be there once you swap.
Even with the new/different sr20det transmission? Im asking this cause im thinking that maybe the driveshaft bolt pattern and driveshaft length will be different after the swap
s14Drifter
May 25, 2009 12:35 PM
