sr20det startup NO CRANK
Old Jan 10, 2005 | 08:29 AM
Skiboard06's Avatar
hey guys i need your help, save me from some frustration. I am all done with my s13 redtop install into my '90 fastback and ready for startup. I tried to start the car and got nothing. I could hear the fuel pump hum and also have all dash lighting and signals. I went to heavythrottle and read through their troubleshooting guide. For an engine that won't crank they suggest to check main power wiring and start signal wire to ECU. I wired the car myself so these connections may be bad and i know what wires they are so i can check them. However heavythrottle also says to check the clutch interlock switch. I do not know what the clutch interlock switch is, where to find it, or what to do if i find it. If you guys could help me out here it would be greatly appreciated thanks
Old Jan 10, 2005 | 03:27 PM
jonpowell's Avatar
Clutch intelock switch is on top of the clutch pedal...did you go auto to 5 speed?
and do you mean no crank as in the engine wont turn over at all or as in it turns over but doesnt start?
try to jump the starter if it wont crank by using a screwdriver and touching the 2 terminals of the starter together...that will tell you if the sterter is A)getting power and B)is blown
Jon
Old Jan 10, 2005 | 03:51 PM
Skiboard06's Avatar
yea it won't crank at all, not turning over so i shouldnt need to touch the clutch interlock switch since i had a manual ka24e before. What is the process i should go through with the starter?
Old Jan 10, 2005 | 03:54 PM
jonpowell's Avatar
Plug in the switch....
There are 2 terminals on the starter...one for CONSTANT POWER STRAIGHT FROM THE BATTERY and one for TRIGGERING THE STARTER FROM THE KEY SWITCH. Make the 2 touch with a long handled screwdriver. Make sure its in neutral though because if its not the car WILL move.
Old Jan 11, 2005 | 08:28 AM
Skiboard06's Avatar
thanks jon ill be trying that
Old Jan 11, 2005 | 11:05 AM
JClark's Avatar
Free bump
Hurry up and get this thing running so I can own you.
Old Jan 11, 2005 | 02:29 PM
Skiboard06's Avatar
m power sucks everyone on here has owned m's wanna start a business? we'll call it ams
Old Jan 11, 2005 | 03:15 PM
JClark's Avatar
AMS would sound good to me if it wasnt this forums main sponsor. We'll have to work on that.
We'll talk about SR20 power vs M power when the SR20 starts making power.
s13silvia123
Mar 19, 2006 08:16 PM
nolimitmr2
Jul 18, 2005 01:49 PM
Skiboard06
Apr 8, 2005 08:21 PM
Skiboard06
Feb 5, 2005 07:46 PM
beefcake6681
Jun 30, 2003 03:39 PM
