Stock injectors and Stock MAFS on programed ecu??
Old Dec 7, 2004 | 05:52 PM
eddawg S13's Avatar
Question Stock injectors and Stock MAFS on programed ecu??
hey ya'll i bought my engine (s13 blacktop) and it came with a ecu my brother in law told me it was programed already and its rated at 14psi... he was telling me that i needed a bigger mafs and bigger injectors to run the engine normal... but i heard of ppl boosting 13lbs on every thing stock and nothing ever happen to their motors.. so i was wondering if i could just use my stock mafs and injectors cuz that would save $$$ if ne body has been in this situation before please tell me what u ended up doing and how it went about.. or if u just have personal knowledge
Old Dec 7, 2004 | 08:26 PM
srslider's Avatar
You should not have a problem running 14lbs. except for on the turbo. If you run it all the time you will dog the crap out of the t25 I personally running 13 lbs and have stock injectors on stock maf.
Old Dec 8, 2004 | 07:11 PM
eddawg S13's Avatar
ok kool... becuz ppl r telling me that its guna lean out the engine (but there dumb a**** ne wayslol) so thats y i was asking to make sure... im guna end up getting a boost controller so i can boost it lower... i dont need power for now thanks for ur info tho
Old Dec 11, 2004 | 06:12 PM
rudee023's Avatar
Might want to find out exactly what the ECU was programmed for. It could be 14 psi on a bigger turbo, Z32 MAF and bigger injectors. Alot different than 14psi on the T25. But with a stock ECU you do not need to upgrade anything to run 14psi except the fuel pump.
Old Dec 12, 2004 | 12:51 AM
eddawg S13's Avatar
i have no idea of finding out... how could i?
Old Dec 13, 2004 | 12:40 PM
jbask's Avatar
I belive he has the "black top" witch if I'm correct has a t-28 not a T-25. So it should hold up 14psi (max).
Old Dec 13, 2004 | 12:50 PM
eddawg S13's Avatar
no i got a s13black top
Old Dec 15, 2004 | 08:43 PM
tErbo b00st's Avatar
Yea you need to find out wat the ecu was programmed for. Otherwise i wouldnt use it. If it was tuned for bigger injectors and/or bigger turbo and/or Z32 MAF you could blow your engine.
W/ a stock ecu (or ecu tuned for stock turbo and injectors) you can run 13-14 PSI on stock injectors as long as you have an FMIC. On the stock Sidemount I wouldnt go above 10 PSI.
Old Dec 15, 2004 | 08:45 PM
you also need to find out how big of injectors it was tuned for if it was infact tuned for larger injectors.
Old Dec 16, 2004 | 04:53 PM
doua's Avatar
i think is fine>..... my red top I alway>> I mean alway boost 14 every day 24_7 is fine.......... all those is good. Stock is fine...
Old Dec 16, 2004 | 07:29 PM
eddawg S13's Avatar
yeah i gonna look into it... i was just thinking about what the hell just get another ecu but stock so i didnt have to go through that mess... just to get that car running already...
insco13
Aug 15, 2006 05:00 PM
advanced240
May 18, 2005 06:03 PM
valencia_ryan
Feb 8, 2005 08:49 AM
thirden
Nov 8, 2004 06:09 PM
kcolyer27
Oct 26, 2004 07:42 AM
