What other parts should I buy?
Old Sep 13, 2005 | 07:33 AM
h22lude's Avatar
I tried to search for other peoples lists but couldn't find much. It is also hard to match lists because most of them are personalized.
Here is a list of parts I am in the process of buying for my S13 SR20DET. Could you let me know what parts I wouldn’t need at this point and what parts I am missing from my list. Right now I am not trying to go crazy with HP. A lot of these parts are for cooling or oil.
Downpipe
High Flow Cat
Exhaust
Hotpipe with BOV
Fuel pump
Motor and tranny mounts
Oil filter
Fuel filter
Intake Manifold (which I will probably wait on)
Intake filter kit
Z32 MAF
Intercooler and piping
Radiator
OEM Thermostat
Dual electric fan
Cooling pan
Boost controller
Turbo Timer
Turbo Manifold (which I will probably wait on)
New gaskets
New belts
New oil pan (if needed)
Oil cooler
Catch can
Here are a few things I am not sure if I need or not.
Adjustable Dual Electric Fan Thermostat Kit, w/ relay and AC circuit from enjuku racing
Would I need bigger injectors yet?
What does a turbo extension do?
Is the oil filter relocater worth it?
Would I need new tranny bushings?
Would I need engine management at this point? I am getting the Greddy Profec B Spec-II Electronic Boost Controller and Greddy Full Auto Turbo Timer which I know isn’t engine management but do I need more or am I good for now?
Old Sep 13, 2005 | 09:47 AM
nsn240's Avatar
the list looks good...
Would I need bigger injectors yet? - no, not unless your going to swap turbos differnent than the t25
Is the oil filter relocater worth it?- pretty sure it just makes it easier to change oil/ fit stuff in the engine bay
Would I need new tranny bushings?- no, but it's a good idea to change while you're there
Old Sep 13, 2005 | 10:13 AM
h22lude's Avatar
Thanks for the info.
Do you know what a turbo extension does? I am guess it moves the turbo but I don't know why.
What about engine management or ROM tuning? Is it needed now or wait until I get a bigger turbo?
Is there anything I should do for my tranny?
Old Sep 13, 2005 | 12:39 PM
nsn240's Avatar
not sure about the turbo extention, might have been a funny name for a downpipe or something have no idea
If you change turbos, injectors or would like to run a little smoother etc, you can get the stock ecu tuned. there's companies that do it, but i'm having a brain fart.
Engine management, you could go with a piggyback if you didnt want to tune the stock ecu, or do both. Stand-alone's are awesome, but very time consuming and tuff to set up
Tranny- wouldnt help to beef it up a little, expecially while its out of the car. It's up to you if you want to upgrade, maybe a 6-puck, or other upgrades
pooptown
Nov 20, 2004 09:51 PM
craigkiel
Jun 17, 2004 12:35 PM
Rynxprs
Oct 25, 2002 12:33 PM
