anyone knows how to relocate the front turn signal? Please help
Hey I just put on my body kit and the front bumper doesnt have a place to put my turn signasl, so i am driving without a turn signal in front. I am planning to relocate the turn signal to my corner light, but i dont know how to do it. If anyone can help, please reply back. Thanks
Originally Posted by dk06
(Post 324275)
^^^what he said+1
its not really tough. the side light is 2 wires. the blinker is 3 wires.
side light: power ground blinker: turn signal power running light power ground cut off the plugs from both lights, using a test light or voltage meter, determine which of the 3 wires on the blinker is the turn signal power. run that wire to the side light plug. run the ground, also. now the side lights are your blinkers, and you just wont have front running lights. you cant make the side light do both, bc it requires a dual element bulb and they dont make one that small. |
my current setup is:
http://lh5.google.com/dapcwiz/RmXKfQ...cLA/s800/3.jpg (had the bumper signal lights shaved with the paint job) to get my corners to blink I kept the original signal lights dangling behind the bumper. I ran the + from the signal light to the - from the corner lamp. Now the corner lights work as blinkers during the day, and still come on as corner lights at night. At night, they blink "off" instead of blinking on if that makes sense. I also ordered a set of amber 921 bulbs to replace the stock 194's. 194's aren't very bright during the day, but 921's fit in the same socket and are plenty bright - just a good idea for safety imo. |
