anyone knows how to relocate the front turn signal? Please help
Old Jul 3, 2007 | 09:53 PM
dk06's Avatar
Hey I just put on my body kit and the front bumper doesnt have a place to put my turn signasl, so i am driving without a turn signal in front. I am planning to relocate the turn signal to my corner light, but i dont know how to do it. If anyone can help, please reply back. Thanks
Old Jul 3, 2007 | 11:01 PM
EM_S13's Avatar
What body kit did you get? Do you have a picture or link? Depending on which one you got you should be able to mount it from the side on the side vents(openings if it has any) w/o seeing it, we cant help much bro.
Old Jul 4, 2007 | 05:33 AM
95240sxmjm's Avatar
^^^what he said+1
Old Jul 4, 2007 | 09:05 AM
Durdan's Avatar
its not really tough. the side light is 2 wires. the blinker is 3 wires.
side light:
power
ground
blinker:
turn signal power
running light power
ground
cut off the plugs from both lights, using a test light or voltage meter, determine which of the 3 wires on the blinker is the turn signal power. run that wire to the side light plug. run the ground, also.
now the side lights are your blinkers, and you just wont have front running lights. you cant make the side light do both, bc it requires a dual element bulb and they dont make one that small.
Old Jul 5, 2007 | 05:18 AM
DaPCWiz's Avatar
my current setup is:
(had the bumper signal lights shaved with the paint job)
to get my corners to blink I kept the original signal lights dangling behind the bumper. I ran the + from the signal light to the - from the corner lamp.
Now the corner lights work as blinkers during the day, and still come on as corner lights at night. At night, they blink "off" instead of blinking on if that makes sense.
I also ordered a set of amber 921 bulbs to replace the stock 194's. 194's aren't very bright during the day, but 921's fit in the same socket and are plenty bright - just a good idea for safety imo.
dk06
Jun 25, 2007 10:12 AM
futureteg
Aug 6, 2006 11:40 AM
RealDS13
Jul 27, 2003 12:43 AM
240fan
Jan 7, 2003 01:50 PM
rbboyl
Jul 18, 2002 08:47 AM
