brake pedal hard
brake pedal hard
my brakes get hot only after driving about a block or so and the pedal gets hard but the brakes still work but when i take my foot off the gas you can feel the car slowing down without putting on the brakes also the brakes are hot and smell.
i change the right rear hose and rebuilt the same caliper.
i disagree, the reason you'd need to bleed the lines is to purge them of air or even old, useless brake fluid. having either of the two in the brake line will would cause the brake pedal to feel soft, or spongy but not hard. a hard brake pedal would most likely be the result of a bad brake booster.
chitodsr
Jan 5, 2008 12:34 PM
95SILVIA14
Apr 2, 2005 02:36 PM
craigkiel
Jun 1, 2004 08:48 PM
s240r
Feb 3, 2004 03:02 PM
Matt_240
Nov 4, 2002 06:22 PM
