**ride Of The Month- Vote Here**
Here it is, the first ever Club240.com Ride of the Month! Below I will post the top 4 (5th nominee did not reply in a timely manner), I will post some pictures and I will post up their mod list. It is up to you, the members, to decide which member gets the honor of being Ride of the Month.
Up first, in no particular order, is Silviaks2ner's car.
Mod Listkyb agx shocks
kouki sideskirts
shorty antenna
oem front lip
rx330 hid projector retrofit
hella projector fog lamps
borbet 16x7.5 alloys
relocated battery
apexi n1 dual exhaust w/ test pipe
sr t25 turbo
370cc sr injectors
walbro 255lph pump
ssac bottom mount turbo manifold
ssac fmic and piping
blitz dd bov
megan downpipe
jgstools oil lines
greddy e-manage blue
ngk afx wideband
ngk plugs/wires
Next up we have, Ayuaddicts car.
Mod List
KTS coilovers
subframe spacers
sportmax 002s 15x8 offset 0
unkown brand 15x8 offset -20
30mm spacer front
25mm spacer rear
kumho ecsta 205/50/15 (F)
costco brand 195/60/15 (R)
ZG fender flares
i have the ITBs but waiting for the fuel management and adaptor plate.
also i completely disassembled, cleaned and replaced the seals and gasket in the engine
Our third nominee is Fireplug
Mod List
Redtop S13 SR20DET
Blitz FMIC kit (23"x10"x2")
Full 3.5" Stainless Turbo-back exhaust
KOYO 2-core racing radiator
Dual FAL 12" fans
Greddy Catch can
Tein HE coilovers
00zx wheels (front) and 16x8 FD wheels (rear)
Mickey Thompson 26x10.5 drag radials
Whiteline polyurethane bushing kit
180sx VLSD
LS Automotive Stage 3 Axles
RPS Turbomax 6 puck clutch
ACT Streetlite flywheel
Driveshaft Safety loop
Greddy intake manifold
Custom top feed fuel rail w/ -8 fuel fittings
MSD top feed 96/lb injectors
Twin Walbro 255lph fuel pumps
Aeromotive FPR
AEM EMS
Splitfire DIS coilpack kit
-8 Stainless braided teflon fuel feed line
-6 Stainless braided teflon fuel return line
Precision PT67 turbo (T4)
Custom 4" intake pipe w/ K&N filter
Sublime Speed Tech Stainless steel top-mount exhaust manifold (8 gauge thickness, 304 stainless)
Sublime Speed Tech Stainless 3.5" downpipe
Tial 40mm wastegate with 1.0 bar spring
Tial racing blow-off valve
Block has been cleaned, decked, and balanced
bored 40 over and powerhoned
crankshaft has been micropolished
CP pistons (9.0:1)
Carrillo rods
ARP Head stud kit
ARP Main stud kit
Power Enterprises 1.1mm metal headgasket
Ferrea double-valve springs,titanium retainers, seats
Tomei Rocker Arm Stoppers
HKS 272 Step 2 cams
HKS Adj. cam sprockets
Comp. 5-angle valve job w/ radius entry
And last but not least, we have Motegineon
Mod List
Kazama Subframe Spacers
Megan Racing Coilovers
Front Strut Bar
Rear Strut Bar
1991 Hicas VLSD
1991 Hicas SE Rear Swaybar
S5 5-Lug Conversion
Trial Zelda Tryforce Wheels (17x9 +14)
J30 Front Brakes
Hawk Pads
Brembo Rotors
S13 SR20-DET
Greddy V-SPL FMIC
Greddy Profec B-spec II Boost Controller
Greddy Auto Turbo Timer
Greddy Type-RS BOV
Greddy Rocker Arm Stoppers
Greddy Metal Head Gasket
HKS Wastegate Actuator
Walbro 255 Fuel Pump
Z32 Fuel Filter
3in. Intake
Flex-A-Lite Dual 12in. Electric Fans
Aluminum Hotpipe
3in. Exhaust
Exedy Cluth
Resurfaced Flywheel and Pressure Plate
C's Short Throw Shifter
Koyo Copper Radiator
Nismo Thermostat
Megan Racing Turbo Manifold
Megan Racing Catch Can
Megan Racing Turbo Outlet
Megan Racing Test Pipe
Megan Racing Downpipe
Exedy Clutch Kit
Mines ECU
S14 T28 BB Turbo
Taka Steel Braided Turbo Lines
Nissan Leopard 550cc Injectors
Z32 Maf
S-AFC 1
Dyno Tune
Kazama Shift ****
Kazama Drift Button
New Shift Boot
Autotechnic Boost Guage
Autotechnic Air/Fuel Guage
Autometer Dual Pillar Pod
JVC CD Player
Imitation Bride Steering Wheel/Hub
Memphis Audio Speakers
Nismo Oil Cap
Bosch H4 Headlight Conversion
Cub240.com Decals
Zilvia.net Decals
kouki sideskirts
shorty antenna
oem front lip
relocated battery
sr t25 turbo
370cc sr injectors
walbro 255lph pump
blitz dd bov
megan downpipe
jgstools oil lines
ngk afx wideband
ngk plugs/wires
Mod List
KTS coilovers
subframe spacers
30mm spacer front
25mm spacer rear
ZG fender flares
Mod List
Redtop S13 SR20DET
Dual FAL 12" fans
Greddy Catch can
Tein HE coilovers
180sx VLSD
Aeromotive FPR
AEM EMS
CP pistons (9.0:1)
Carrillo rods
ARP Head stud kit
ARP Main stud kit
HKS 272 Step 2 cams
Mod List
Front Strut Bar
Rear Strut Bar
1991 Hicas VLSD
S5 5-Lug Conversion
J30 Front Brakes
Hawk Pads
Brembo Rotors
S13 SR20-DET
Greddy V-SPL FMIC
Greddy Type-RS BOV
Z32 Fuel Filter
3in. Intake
Aluminum Hotpipe
3in. Exhaust
Exedy Cluth
Nismo Thermostat
Exedy Clutch Kit
Mines ECU
S14 T28 BB Turbo
Z32 Maf
S-AFC 1
Dyno Tune
Kazama Shift ****
Kazama Drift Button
New Shift Boot
JVC CD Player
Nismo Oil Cap
Cub240.com Decals
Zilvia.net Decals
