0-60 times
Old Oct 29, 2003 | 07:53 PM
fist's Avatar
0-60 times
just a question for anyone with an s14 and an automatic tranny..
what is your 0-60 time???
i checked mine and it was like 13 seconds!!??!?!??!!
i checked by the time on the cdplayer...but still...my car doesnt seem all that fast..
Old Oct 29, 2003 | 08:00 PM
iblowmindz's Avatar
thats pretty sad
Old Oct 29, 2003 | 08:06 PM
i belive its around the high 8s or low 9s seconds
Old Oct 29, 2003 | 09:15 PM
crimsontide240's Avatar
13 seconds?? damn man. That doesn't sound right at all. Chec your car out man. If you really are runnin 13's than you got a problem somewhere.
Old Oct 30, 2003 | 02:23 AM
fist's Avatar
yeah no ****...
maybe it's just got too much weight?
theres new brakes on the back...maybe they are actually a little too tight and slowing me down some?
maybe it just needs a tuneup?
is their a certain way you launch in an auto? cuz i just mashed it at the start? should i rev it up in neutral and drop it into gear with the revs up? i REALLY didnt wanna put that kinda stress on the engine...but maybe it's not that much stress for these cars i dunno? i know i did it all the time in my tempo...and now the engine oil and tranny oil both leak...lol..i also did it in my dads topaz and its now got a busted engine mount
Old Oct 30, 2003 | 02:25 AM
fist's Avatar
it seems to me that first gear is pretty slow...
i mean i take off over drive and tried to do a brake stand ( hold brakes and press the gas....smoke show..) but the rp's wouldn't go up over like 2000 or 2500...it was sad...the tires did start spinning but it should have revved up as soon as they did...i dunno im thinkin something with the rear brakes.
Old Oct 30, 2003 | 06:17 AM
iblowmindz's Avatar
first of all, doing a "neutral drop" is about the worst thing you can do to your car other than driving it off the end of a pier into salt water... NEVER DO IT!!! plus, doing brake stands twists the hell outta your car... in order to launch with an auto, you need to stage your car by holding your foot on the brake and revving your engine up till the tourque converter starts to catch, around 3,000 rpm's in my 95 altima with the same engine.. when it starts to catch, jam the gas and let off the brake at the same time, you should only chirp your tires to get the best 0-60 time, try different rpm's to find which has the least bog down and not much tire burn.. hope this helped -scott
Old Oct 30, 2003 | 08:52 AM
GUNLINE's Avatar
13 seconds AHHHHHHHHHHHH HHAAAAAAAAAAAAAAA
what the **** is that!!
Old Oct 30, 2003 | 09:36 AM
drnovascotia's Avatar
i'm pretty sure I can run a 0-60 in less than 13 seconds, so your time has to be wrong. Secondly, with the slowness and smoke coming out of your pipe, you HG could be gone, but more than likely that smoke means you're burning oil, NOT GOOD!
And dont do a neutral drop, your tranny will die real quick. And revving while in Drive with an auto, there is a rev limiter, like 180 or 2k rpms or something like that, thats how my s13 was.
Definately do a tune-up to the car, new plugs, o2 sensor, 300zx fuel filter, etc.
Dr.
Old Oct 31, 2003 | 02:07 AM
fist's Avatar
my hedgasket is good
by smoke show i mean burn out lol...no smoke coming from my pipe but from my tires. its just the car wont rev..
and i cant even hold the brake and get my car to 3 thousand rpms....it accelerates like a ****ing moose...and traction breakes before than that and once the traction breaks it doesnt rev any faster...like it should.
Old Oct 31, 2003 | 05:27 AM
well like I said, in drive there is a governer that won't let you rev past 2K rpms, I found that out @ the track. Might not be on your 91, but it is on my 93
And I drive a 93 and it's definately not as slow as a moose, you should definately see whats up.
Dr.
Old Mar 3, 2004 | 05:19 PM
fist's Avatar
how exaclt can there be a 2000 rpm rev limiter in drive...then we wouldnt be able to drive past 2000 rpm anywhere
Old Mar 3, 2004 | 07:38 PM
tommyboy's Avatar
I have no clue what is up with your car. Sounds pretty f'ed up. My 92 will hold till 3,000 rpms then light the rear tires like they are spinning on ice. As far as 0-60, my best is 7.9 seconds. I think your car has a plug up its butt or something. But most def do a good tune-up and clean the MAFS. That should help.
Old Mar 3, 2004 | 09:21 PM
MrRonatron's Avatar
Dont push the brake all the way down as hard as you can, theres a sweet spot, you just need to find it, experiment with different amounts of braking...
Old Mar 4, 2004 | 12:48 AM
Driftmonster's Avatar
Sell your car...... let someone else have it!
Driftmonster
http://www.geocities.com/wardog5811/SR20det.html
