1st time s14 owner w/ questions
i bought a well maintained 95 s14 se w/ 64k at the beginning of this month. i have a few questions.
1. is there anything i need to know about the car e.g. any weak points in the car that need replacing?
2.where can i find some nismo floor mats?
3.does anybody have good condition sunroof trim?
4.anybody selling the oem lip?
5.any bolt-ons that have given people good power but reasonably affordable?
I'd do a basic tuneup and just replace the basics. Does Nismo even make floor mats for s chasis? I know every one I have seen on ebay so far are fake. Post in the wanted to buy section for the lip and trim.
if your wanting cheap bolt-on power, go get a set of stock S13 cams ( 1991-1994 ) to replace your stock s14 cams.....( they give you more midrange and topend power )....The stock s14 cams suck A** from 5000 RPM's to Redline.......ill post a link if you need help with the install.....i'm doing the swap very soon and this should only $$ you about $100.00 if you do it your self or it could be anywere between $300 and $600 if you get somone elce to do it...........i would say replace your timing chain, but your KA only has 64K on it so you sould be ok......but i do recommend removing your timing chain guides while you have the Valve cover off.
Pistolleros13
Mar 24, 2009 12:18 AM
Electrotek
Feb 9, 2005 06:54 PM
