240 trims and options
Originally posted by -HyJynX-
http://auto.consumerguide.com/auto/u...9071990203.htm BAM
You guys are silly. In '89-'90 there was only 2 trims XE and SE. XE was the coupe and SE was the hatch. In those years the trim had nothin to do with options only the body style. In '91 they did away with that system and had actual trims base and SE for coupes and base, SE, and LE for hatches.
You guys are silly. In '89-'90 there was only 2 trims XE and SE. XE was the coupe and SE was the hatch. In those years the trim had nothin to do with options only the body style. In '91 they did away with that system and had actual trims for both the coupe and hatch... base, SE, LE.
