adjusting idle?
Old Jul 29, 2005 | 10:49 PM
iNmotioN's Avatar
adjusting idle?
my cuzz got a 90 240 and it idels a little higher than 1 thou rpm. and we couldnt find where that thing where you adjust is at. any ideas? thanks.
Old Jul 30, 2005 | 07:14 AM
Cape 240's Avatar
is that with the A/C on? it will idle higher with AC on.
Adjust your thrttle cable, that should also lower it (its to the right of the throttle body)
And if you cut your intake box, and remove silencer (*search it*) you will idle about 150 lower.
Old Jul 30, 2005 | 10:18 AM
FinaL's Avatar
my car runs high on ideal butt goes to 900 when its warmed up
is that good??
Old Jul 30, 2005 | 11:33 AM
nn240sx's Avatar
idle will be higher the more hp you have usually...
Old Jul 30, 2005 | 11:58 AM
lrb_2000's Avatar
lol... there's a screw on the throttle body for the ka24e I believe... you need to warm your car up, and unplug the TPS sensor before you change it.. then plug it back in... have him buy a book, or download the FSM.. it will save you a lot of hassle.
mine idles about 700.. with the AC on it's around 950. I'm going to take the AC out though, I don't even use it..
Old Jul 30, 2005 | 01:00 PM
Cape 240's Avatar
mine idles around 750 and about 1,000 with a/c
Old Jul 30, 2005 | 08:21 PM
Preston's Avatar
700-750 is normal for the ka...with A/C it will be higher. Those sound like good numbers. You're all alright.
70Challenger
Mar 4, 2006 06:55 PM
nsn240
Oct 17, 2005 01:18 PM
KeN VeRsUs RyU
Aug 5, 2005 05:32 PM
Ncal
Jan 22, 2005 04:16 PM
NOS_is_4_cheat
Dec 22, 2003 06:16 AM
