Adjusting S15 Headlights
Old Feb 28, 2006 | 03:40 PM
70Challenger's Avatar
Is there any form of adjustment on the low beam on S15 headlights? Mine aim pretty low
Old Feb 28, 2006 | 03:44 PM
barcode's Avatar
maybe you could put like a washer or somthing under the bottom bolts you have holding them on. If you used the S14 core support, its all ghetto anyway so i dont see why that wouldnt work.
Feel free to correct me, just putting an idea out there.
Old Feb 28, 2006 | 03:54 PM
i used an s15 core support, i was thinking about putting some angled washers in the front to tip the whole light up (there is only one bolt that connects to the front of the core support), but i wasnt sure if there was a better way to go about this, or if you could adjust the beam within the light housing somehow
Old Feb 28, 2006 | 04:17 PM
barcode's Avatar
that was kinda what i was thionking you could do, i couldn't think of any other way
If you dont mind me asking, how much did a body shop charge you to put the core support on, you dont have to tell me I was just curious because I am in the process of doing it right now and I want to hear what some other bodshops say, instead of in this little hick town.
Old Feb 28, 2006 | 04:40 PM
I dont mind tellin, they charged nothing, zip, nodda...
Thats because they didnt do it. lol I bought my 95 with some front damage, but a clean title. I found a guy in spokane that sold me the front end conversion, then sold me the radiator core support for 150 shipped. My dad and I welded it all on with a Harbor Freight MIG, (my dad used to be a proffesional welder, I on the other had have very little experience). I had to weld in a strut tower too. It took awhile fitting everything before welding, but it wasnt that bad. I do recommend buying the harbor frieght air chizel for 9 bucks. It made popping off the welds on the old radiator core support a breeze. If you know anything about welding, you could easily do this yourself in a few hours, it took me longer because i had to replace the strut tower, and that took alot of time measuring so I didnt screw up. I can email you photos or something if your curious about how to do it, or I might make a thread later about it.
Old Feb 28, 2006 | 05:17 PM
there should be some in-place screws that push and pull the internal mounting bracket. look near the bowl of the projector and there are probably 3 adjustments, one for left and right and two for up and down. aim them so that the upper part of the cutoff line has dropped 2" at 25' distance (you may need to find a white wall for this) the reason you probably want to aim the lights higher is they are not dot spec and the beam pattern is higher on the left side lighting up oncoming lanes instead of yours. take into account other drivers saftey when doing this (really annoying to have the lights shining in your face)
Old Feb 28, 2006 | 08:24 PM
barcode's Avatar
yeah i would appreciate that(you e-mail me some pics) you wouldnt happen to be able to get another core support fo that cheap would you, I only found them for like $300. my e-mail is fbm_bikes_rock@yahoo.com Thanks for that help.
Old Feb 28, 2006 | 09:09 PM
I appreciate the help, i am still alittle confused... Is it any of these screws? Am I even close?! lol Yeah I dont want them to blind people, just high enough so I can see. I appreciate the help!
Old Mar 1, 2006 | 09:44 AM
can anyone help to clarify this?
Old Mar 1, 2006 | 02:15 PM
it's going to be vert adjustment with the two left A's and lateral with the B (you dont need to mess with B) you can either screw the bottom left A counter clockwise or screw the top left A clockwise
Old Mar 1, 2006 | 02:17 PM
that lamp is aimed down pretty significantly .notice how far up it is where the bulb fits into the projector (it's pointing down)
Old Mar 4, 2006 | 12:31 AM
It worked great, i just tightened the top "A" with a 5/16 open end wrench, and it raised those suckers up nicely (not annoying/distracting high, but high enough i can actually see!) Thanks for the help!
Old Mar 4, 2006 | 06:55 PM
yeah man, glad it worked out for ya
nsn240
Oct 17, 2005 01:18 PM
KeN VeRsUs RyU
Aug 5, 2005 05:32 PM
iNmotioN
Jul 30, 2005 08:21 PM
Ncal
Jan 22, 2005 04:16 PM
NOS_is_4_cheat
Dec 22, 2003 06:16 AM
