air/fuel gauge connection ?
Where do I hook up the power so my air/fuel gauge turns on when the ignition is on and can I splice into a ecu wire instead of running it hrough the firewall all the way to the o2 sensor?
Thanks Ryan |
For power, just splice into anything that comes on with ignition, and, yes, you can splice the O2 wire at the ECU instead of going through the firewall.
wheres the ecu located in the 95 240sx
it should be on the kickpannel area on the pasengerside.
Originally posted by AmIdYfReAk it should be on the kickpannel area on the pasengerside. |
thanks for the answer but one more thing how do u connect it to the ecu
Originally posted by sr20 learner thanks for the answer but one more thing how do u connect it to the ecu If you can wait about 7 days I can tell you step-by-step since I'm getting my gauge set soon, and one of them is an a/f :thumb: |
ok thanks ill wait
