air/fuel gauge connection ?
Old Jul 9, 2004 | 01:27 AM
ryan15's Avatar
Where do I hook up the power so my air/fuel gauge turns on when the ignition is on and can I splice into a ecu wire instead of running it hrough the firewall all the way to the o2 sensor?
Thanks
Ryan
Old Jul 9, 2004 | 06:12 PM
ziggy682's Avatar
For power, just splice into anything that comes on with ignition, and, yes, you can splice the O2 wire at the ECU instead of going through the firewall.
Old Jul 10, 2004 | 07:09 PM
sr20 learner's Avatar
wheres the ecu located in the 95 240sx
Old Jul 10, 2004 | 07:47 PM
AmIdYfReAk's Avatar
it should be on the kickpannel area on the pasengerside.
Old Jul 11, 2004 | 04:55 AM
"should be"? heh... actually it is. To clarify, that plastic cover to the right of your feet when you sit in shotgun... you might want to remove the right sill panel first... and you have to unbolt the whole ECU from the body to get to the wires because the ECU harness is positioned at the front (towards the engine bay). Also, disconnect your neg. battery post before doing this to avoid any strange static damage, etc.
Old Jul 11, 2004 | 01:15 PM
thanks for the answer but one more thing how do u connect it to the ecu
Old Jul 11, 2004 | 07:06 PM
find the correct wires (there's a ECU pinout diagram somewhere here) and carefully splice the a/f sensor wire in.
If you can wait about 7 days I can tell you step-by-step since I'm getting my gauge set soon, and one of them is an a/f
Old Jul 12, 2004 | 12:12 PM
ok thanks ill wait
battosaii930
Jul 8, 2007 09:37 PM
dre42
Jun 24, 2007 02:35 AM
topsecretgold
Aug 4, 2005 10:31 PM
ridesnowx4
Jan 24, 2004 05:05 PM
Dom
Feb 10, 2002 12:03 AM
