apexi rsm g-sensor install
Old Aug 29, 2007 | 07:15 PM
RBfastback's Avatar
how do u install the g-sensor, where do the purple white and black wires go? help!!
Old Aug 29, 2007 | 08:37 PM
you just plug the sensor into the bottom of the the rsm itself...
Old Aug 30, 2007 | 07:39 AM
RBfastback's Avatar
ya that was easy i knew that, but it dosent work unless u plug the other 3 wires into something. i just dont know where they go
Old Aug 30, 2007 | 12:18 PM
na you don't plug them to anything... those are used for other models.
mine works fine
Old Aug 30, 2007 | 07:00 PM
RBfastback's Avatar
for some resom my speed sensor wont work, where did u mount your g-sensor??
Old Aug 31, 2007 | 03:46 AM
ahh the speed sensor has nothing to do with the g meter. .. you have to hook the speed sensor to the vss on the ecu... i mounted my g meter on the dash..
also with the speed meter you must set it up... for the weight of the car etc... if you don't have the book brother.. you can get it at apexi.com
in pdf form. let me know if you still need help.
Old Aug 31, 2007 | 04:41 AM
clubredsilvia's Avatar
http://http://www.apexi-usa.com/pdf/technicalDocumentation/199.pdf
there you go, chief.
Old Aug 31, 2007 | 09:02 AM
RBfastback's Avatar
cool, got it thanks
s13slider44
Oct 1, 2006 05:47 PM
gmckey
Nov 30, 2003 06:47 PM
bztech
Nov 24, 2003 09:55 PM
manos1984
Sep 29, 2003 08:56 PM
blk90s13
Aug 22, 2003 04:29 PM
