Attn 240 gurus
Attn 240 gurus
I have a 95 s14
K so my car is ackin up. When i hold the pedal at 1000rpm the needle will vari about 200 rpm then smooth out till 3000 and even when i full throttle in a low gear it will maintain speed and even start to buck. K so hears what I checked
1. timing is dead on, yes i did the sequence
2. Vaccum checks all good
3. Compression all perfect every cylinder
4. new maf
5. new Throttle position sensor
6. new fuel filter
7. Fuel pressure perfect
8. New cap plugs and rotor
Only trouble code i get is crankshaft position sensor and we all know how usless that is. One thing i noticed was when running the timing light and accelerating the timing light wasnt smooth it kinda skipped or sumtin anyone????
4. new maf
6. new fuel filter
SoupBA
Aug 27, 2004 01:25 AM
