Automatic seat belt system failure
Hi People!
Got a little problem with the Belt system mentioned in the subject.
The problem is, that the right shoulder belt is functioning , but the left one won't move. (It's frozen in the driving position)
Don't know if it's a power problem or something else.
The warning lamp is workin' and also the doorswitches do.
Somebody got an idea?
Thnx
Thnx
Try some grease in the tracks. If all else fails. Pull it all the way back & unplug it.
The guide could have broken, ect.. The easiest way to find out is to just take off the pillar pannels & look at it. Most of the time the damage is obvious.
Could it maybe be the Fusebox? Because i had to work on it and then could unfortunatly kick out some cables? (The question is, where to find the control unit of this system)
