power window failure
Old Jan 24, 2006 | 02:07 PM
Agent_Zero's Avatar
Unhappy power window failure
Recently my driver side power window stopped in a halfway down position since then my car has been broken into. I can't seem to figure out the problem as far as I can tell I think its the motor. Is there anyway to manually move the glass up to avoid replacing the motor? If its bad? Any help would be appreciaed.
Old Jan 24, 2006 | 07:40 PM
Preston's Avatar
You'll have to remove the regulator first and put the window up then set the regulator back to up also. I can almost guarentee it's the motor (aka check fuses for it and relays and stuff...not just motor) unless you have something blocking the path.
Old Jan 25, 2006 | 12:40 AM
shglbmx's Avatar
you can try disconnecting the cable that is connected to the power window switch and hooking it up to a battery. then, after the window is rolled up, try and figure out how to fix it.
Old Feb 2, 2006 | 11:13 AM
Agent_Zero's Avatar
thank you I give it a shot
Magius360
Mar 31, 2011 02:54 AM
soul strong
Oct 2, 2008 06:31 AM
Picur
Apr 5, 2004 12:00 PM
S13Nissan240SX
Apr 22, 2003 02:59 PM
boro240
Oct 17, 2002 09:01 PM
