automatic seat belts aren't working
Old Jun 2, 2006 | 08:17 PM
kingcarm's Avatar
MY automatic seat belts that are suppose to come across your body when you shut the door, aren't working. Is there a fuse or is there something else that is causing them not to work? Any feedback is greatly appeciated.
Old Jun 2, 2006 | 09:31 PM
MaximJ's Avatar
Lolz I dont even think that its fuse man, if its 240 well its time to die basically, just go on the yard and take some over there easiest way to fix it...
Old Jun 2, 2006 | 09:43 PM
ReigH's Avatar
the motor is dead. go to the dealer and they are required by law to fix it for free. if you dont want to deal with the motor dying in the future you can disconnect the motor when the seatbelt is on the up position so all you have to do is unclip the seatbelt everytime.
Old Jun 3, 2006 | 03:23 AM
Yep, dealer will fix it, it will take awhile buts its free so you can't really complain...
Old Aug 15, 2006 | 09:18 AM
dokta's Avatar
Are you sure they are required by law? I need to find that law so I can show it to a dealer. The two dealers I went to basically told me to go to hell.
Old Aug 15, 2006 | 09:57 AM
It is a factory recall by Nissan, they have to fix it for free if it fails on s13's. Don't know if this link will work, let me know if it does or not. Here's a quick copy and paste as well.
Defect Description:
THE FRONT SAFETY BELT BUCKLE RELEASE BUTTONS CAN BREAK. THESE RED PLASTIC RELEASE BUTTONS ARE MARKED "PRESS." IF A BUTTON BREAKS, PIECES CAN FALL INTO THE BUCKLE ASSEMBLY CAUSING THE BUCKLE TO OPERATE IMPROPERLY.
Consequence of Defect:
THE SAFETY BELTS WOULD NOT PROVIDE ADEQUATE PROTECTION TO AN OCCUPANT IN A VEHICLE CRASH.
Corrective Action:
OWNERS SHOULD PROMPTLY CHECK THE CONDITION AND OPERATION OF BOTH FRONT SAFETY BELT BUCKLES AND CAREFULLY INSPECT THE RED RELEASE BUTTON FOR ANY BREAKS OR CRACKS. THEY SHOULD ENSURE THAT BOTH BUCKLES ARE OPERATING PROPERLY BY INSERTING EACH LATCH PLATE INTO ITS BUCKLE, TUGGING ON THE BELT TO MAKE SURE THE LATCH IS SECURELY LOCKED, AND THEN PRESSING THE RELEASE BUTTON. THE LATCH PLATE SHOULD POP OUT OF THE BUCKLE WHEN THE BUTTON IS PRESSED. IF EITHER RELEASE BUTTON SHOWS A SIGN OF BREAKING OR CRACKING OR IF EITHER BUCKLE FAILS TO OPERATE PROPERLY, OWNERS SHOULD PROMPTLY CONTACT THEIR AUTHORIZED DEALER TO SCHEDULE AN APPOINTMENT TO HAVE THE BUCKLE REPLACED OR REPAIRED FREE OF CHARGE.
Old Aug 15, 2006 | 04:57 PM
Darkvillin's Avatar
this is a very valuable tidbit. thank you reigH and s13. i honestly had no idea.
Nissan_240sex
Apr 5, 2010 09:25 PM
kevtrinh
May 21, 2006 07:51 PM
blacks13
Aug 21, 2004 06:35 PM
blacks13
Aug 16, 2004 03:16 AM
Abdukted
Oct 2, 2003 10:56 AM
