battery problems
Old Mar 13, 2009 | 06:06 PM
smoken805s14's Avatar
battery problems
again my new battery is dieing, but checked the alternator and its good....someone said it might be a transmission coil thats why it's not charging...i really need help ....i need suggestions
Old Mar 13, 2009 | 06:10 PM
oh yeah and my air bag light blinks on and off before my battery dies...
Old Mar 13, 2009 | 07:08 PM
did this someone happen to tell you what and where this coil is? the closest thing to a transmission coil that i can think of would be what nissan calls a starter coil. it's part of the alternator.
Old Mar 13, 2009 | 07:55 PM
no....what else do you think it can be?
Old Mar 13, 2009 | 08:14 PM
it can be a lot of things but i was hoping you had been told what this transmission coil is. otherwise it just sounds like someone was pulling your leg. so what exactly happened that caused the battery to die? did you crank the engine until the battery died or did you just park the car and it didn't start when you went to start it?
Old Mar 13, 2009 | 08:38 PM
okay so i took my car to kragen after i got the battery charged and they tested it with my alternator in it...and they said my alternator was bad....all this trouble for the first thing i thought was wrong...i guess it's better to check the alternator while its in your car instead of taking it out and getting it checked...so i'm going to get a new one...you know where they are cheap? i'm going to start looking around, but yeah thanks for your help
Old Mar 13, 2009 | 09:34 PM
shaban's Avatar
http://cgi.ebay.com/ebaymotors/95-96...QQcmdZViewItem
Old Mar 13, 2009 | 10:28 PM
mine is a 90 amp...and i got the fog lights so i'm not sure if that will work or will it?? also i saw this alternator that said one wire alternator what does that mean? are they all one wire?
mrjchinchilla
Jul 13, 2009 02:25 PM
bigbird
Dec 20, 2004 06:34 PM
Import Fanatix
Oct 24, 2002 06:45 AM
leiferik1
Jun 20, 2002 06:46 PM
RNN14
Mar 20, 2002 02:34 PM
