1998 DOHC Behind the battery wiring problems - need help
Old Dec 20, 2004 | 03:54 PM
bigbird's Avatar
Hey guys,
Doing a swap on a 98 240SX - s13 red top is coming in. Having trouble with the wiring behind the battery tray.
According to srswap instructions and etc there should be 3 plugs. Well they are referring to an SOHC KA24DE , not the DOHC.
I only have 2 plugs, and their wiring colors do not match up at all.
I am unable to locate the proper wiring diagram.
Please help.
Thanks!
Old Dec 20, 2004 | 04:30 PM
2fast4y0u's Avatar
im in the process of doing the same swap. are the plugs on the new harness or are they aprt of the car still? i sent my harness out to be modified so i just have to plug and play.
Old Dec 20, 2004 | 06:34 PM
bigbird's Avatar
Well - the wiring is fairly simple - I've completed all of it already; except the mystery plugs.
Its actually the wires from the FUEL PUMP RELAY; AC RELAYS ; ECU BACKUP WIRE; etc. that do not match all existing how-to's.
I think its because they are for an old SOHC model, not the 95+.
If anyone has a clue - please chime in
upgrade
Oct 28, 2011 05:34 AM
mrjchinchilla
Jul 13, 2009 02:25 PM
pumaking
Nov 6, 2005 09:03 AM
2-FORTY_TERROR
Mar 12, 2003 11:08 PM
