blew my exhaust manifold gasket
Old Jan 31, 2010 | 01:46 PM
yea some how its gone bad, i had a OEM s15 copper exhaust manifold gasket and it was only a couple months old and now i got a leak from the gasket. dont know how it happened but i was thinking of getting a cometic exhaust gasket looks good but anyone have any experience with them?
heres a link to the gasket
http://www.frsport.com/Cometic-MLS-M...T_p_12519.html
Old Jan 31, 2010 | 03:53 PM
What manifold are you using?
Old Jan 31, 2010 | 04:14 PM
Tomei Expreme
Old Jan 31, 2010 | 04:38 PM
I would have the clearances checked on that first. Exactly how did the gasket blow? Are you sure a stud or two didn't just back out a bit?
Old Jan 31, 2010 | 04:46 PM
tell you the truth i never checked the stud lol. might be what it is but i noticed cause i started smelling somthing funny then i sprayed carb cleaner into my IAC valve to clean it out and ungunk it and all the unburnt carb cleaner that passes through the motor was dripping from the gasket.
Old Jan 31, 2010 | 09:01 PM
its your studs... trust me battorious
if they are loose it will create a problem. Hot gasses that are suppose to go into the manifold tubes just run off onto the gasket.... if its one of those... shinny peices of sheit... they will melt.
Old Jan 31, 2010 | 09:09 PM
so do i need a new gasket? anyway i ordered it was only $35 lol
sonikfuri
Jan 28, 2007 07:25 PM
s13slider44
May 20, 2006 01:10 PM
Otterman
May 4, 2006 10:30 PM
KuhnDawg
Aug 16, 2005 08:51 PM
altima/240sx
Sep 23, 2002 11:50 AM
