car turned off on me
Old Nov 19, 2007 | 05:12 PM
rened11384's Avatar
ok i was heading home after work...came to a light then it just turned off...i had the car in nuetral...so i know i didnt stall out it turned back on and it did it again when i got to my friends house...im thinkin its the starter...kinda stumped so any suggestions would help
Old Nov 19, 2007 | 07:45 PM
a bad ignition coil will act up in this manner when the surrounding temperature gets to a curtain point. the starter is only used to start the car so if it starts fine then you can rule that out as a possibility. the alternator on the other hand can also cause your car to die like that.
the list of possibilities is long so rather than frighten you with everything that could be wrong with your car you should give some more info. that way it can be narrowed down some.
Old Nov 20, 2007 | 10:12 AM
Initial Daniel's Avatar
Bad grounding in your electical system can do that too. But to echo what jramos said, tell us more...
Old Nov 20, 2007 | 10:14 AM
Or the battery terminals arent tight enough or are corroded. That will cause exactly the problem you said. My vote is that or the alternator.
Old Nov 20, 2007 | 10:22 AM
Moving this to the "General" section
USMCDrifter
Sep 21, 2007 08:25 AM
RMS13FU
Aug 23, 2007 09:18 AM
70Challenger
Sep 1, 2006 09:17 PM
smokey240sx
Feb 25, 2005 06:35 PM
duckman240sx
Sep 8, 2003 02:33 AM
