Chain Rattle
Chain Rattle
Sup i just recently swaped a KAde into my car. a little after driving it i hear the dreaded chain rattle.
i already read the timing chain guide a while back.
after removing the guides has anyone had any very bad experiences
weren't they put there for a reason? I know nissan RECOMENDS removing the top one.......but why DONT they recomend removing the others?
HMMMM. I need to do this asap too, but i don't know about removing anything other than the top....
any recomendations/ideas???
thanks!
thanks!
the upper timing chain is a little loose but it is not loose enough to jump a tooth or anything... i tried to get mine to jump time with a 24 mm socket and a 1 inch wrench... it would not even budge... if you have done a timing chain replacement or a rebuild on these motors you will see that the chain is not loose enough to harm anything... thats how i found out...
i bought a new set for my motor that should be back together and running this week... i am going to keep an eye on them just in case... at the first sign of noise they are comming back ot again...
l2aine
Aug 10, 2009 07:24 PM
